G. Pfrommer
    10
Reputation
0 Neutral
Personal Information
  • Location
    GA USA
  1. What is the possibility of the Truss Tape Plugins being implemented to 2017 from Autoplot VW? It is a VERY valuable tool, The new Dimension Tape plugin is useless since you can not export the information via the User Fields, keeping me from making labels for truss tapes.
  2. I seem to remember that you could create a Focus Symbol, for example take a symbol of a piano and make the entire symbol a focus point. Is this possible to do without creating a focus point or am I thinking of a different software.
  3. Greetings Does anyone know the best settings for the Nvidia Quadro K5000 to work with Vectorwork 2013. I just installed it and Vectorworks seems to run slower than the Nvidia GTX 580 I had in the machine before. I'm starting to wonder if the $2 I spent on the graphics card was worth it.
  4. Greetings, I'm using Design 2013 with Jan 18 SP update I have created truss and converted it to a lighting position. I keep truss and lights on separate layers for plotting purposes. When I try to insert a lighting fixture on the same class as the truss it works fine. If I change class to other than the truss class and insert the fixture it will snap to the object but when I place it is appears below 0' and does not hang on the truss. The only way that will work inserting a fixture on a truss on a different class if I have the "Show/Snap/Modify other" turn on in the classes options . Why cant I do the same thing with the "Show/Snap" option
  5. Greetings All, Is there, or has anybody created a macro to repeat the last command, similar to AutoCadd's right click option. I'm finding it tedious to continue running though menu's Thanks Greg Pfrommer Marietta GA usa
  6. Hi Shelley, I would agree with your thinking, My hopes is that someone might be able to write an add on that would take a coordinate from the hanging position and each lighting fixture and do the math to give a distance from a set point, either the start or center of the hanging positions. G
  7. Has anyone had any luck on exporting the position of a lighting fixture relative to the start of a lighting position and not the origin. I.E. The start of a 10'lighting position starts at (10',15') with 5 fixtures evenly spaced with the first fixture 5" from the start of the lighting position. instead of the first fixture being at (10'5",15') I would just like to have the measurement of (0'5"). Of course I would want this to happen in any axis of the x and y planes. I know this involves some complex math, and I would even be willing to purchase a plug-in if someone was able to create this option Thanks Greg Pfrommer Marietta, GA
  8. Thank you for the help, but I don't understand why this is so difficult. On complex raked lighting positions, this will be a BigPITA!!. On the other 3 software programs I use for designs, I don't have any problems with 3d not to mention doing the same effect with half the steps. Is this a concern to Nemetsheck or just another inconvenience I have to deal with? G
  9. OK, Ive been fighting with this for over an hour. Ive tried to rotate a lighting position for a vertical torm position. Spotlight will only allow me to draw/Rotate/Convert lighting positions in the Plan view. I have been searching the help PDF but haven't fount anything to assist in doing this Any Help would be greatly appreciated Thanks G
