Jake DeGroot Posted January 5, 2013 Share Posted January 5, 2013 I am trying to change the projector symbol being used for my Video Screen objects. For some reason, though, the list is empty besides the current "Projector-Small" option. When I first began inserting video screens, I could not get the projector to display at all. The list was empty and even with "Projector-Small" selected as it was by default, nothing was visibile. I was able to sort of fix this by manually importing the "Projector-Small" symbol from \Libraries\Defaults\Video Screen\Projector Models.vwx into my current drawing. When I did this the projector showed up. So I tried importing all the rest of the symbols too, but still, "Projector-Small" is the only one on my drop-down list. What I really want to do is make some custom ones as described here but I can't even get the other stock ones to show up. Any ideas? Quote Link to comment
C. Andrew Dunning Posted January 7, 2013 Share Posted January 7, 2013 Jake - Sorry you're having issues... Some questions in order to help you: What VW version are you running? Have you recently upgraded or reinstalled VW? Might you have copied the projector resource file from another computer that might be running a different VW version? Did Video Screen projector placement ever work on your current computer? Do the other video tools that import Symbols (Television, Blended Screen/Projector) work? Does the "Stand" function in Video Screen work? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 7, 2013 Vectorworks, Inc Employee Share Posted January 7, 2013 Do you have "Display default content" turned on in the Vectorworks Preferences? Do you seen the same behavior when starting from a new blank document? (Not an existing file or starting from a template.) Quote Link to comment
Jake DeGroot Posted January 7, 2013 Author Share Posted January 7, 2013 (edited) Thanks for the response, guys. Good news Klinzey's idea of making sure the "Display Default Content" preference was turned on fixed everything. Not even sure why I had it off, but turning it on made the list work. Thanks again! Edited January 7, 2013 by jaked Quote Link to comment
