Moon Door
1. Create the geometry for the door frame. Make sure the bottom of the frame is at Z=0.
2. Create the geometry for the wall cut out. (extrude of door frame + opening). Make sure the bottom of the cut out is at Z=0. make sure extrude is thicker than wall.
3. Create 2D geometry for door graphic
4. Select all. Create a symbol.
5. Edit the symbol. 3D part. Select the cut out geometry. Cut.
6. Right click on an empty space. Choose "3D Wall Hole Component". Paste in Place.
7. Insert a dummy door with the door tool.
8. In the OIP choose Settings. In the General Tab, check Use Symbol Geometry. Navigate to symbol.
example attached.
ubbthreads.php?ubb=download&Number=8363&filename=Screen%20Shot%202012-11-22%20at%2010.28.03%20PM.png
hth
mk
Edited by michaelk
