So today I tried using some default content from the Entertainment library. I used a round banquet table, a covered chair and a couple of Eurotruss pieces. I put them together into a simple hall layout with seating for 500 (50 tables with 10 chairs each). These are the problems I found -
- chairs and tables are poorly made for rendering well. If you try and do a straight front elevation or section of the room using a sheet layer viewport and hidden line rendering Vectorworks crashes (my system is brand new, top end retina Macbook Pro). If you can only get beauty renderings and not the basic elevations from the model, what's the point?
- the table symbol had its origin centred on its 3D geometry, resulting in the tables being sunk into the floor. Why should I be fixing basics?
- The tables auto generate a "cloth" class but the elements aren't even set to by class in the symbol.
- the Eurotruss pieces (a straight section and a corner) don't even line up in front/side views the way the symbols are built. I should be able to drop it on the plan and it should line up in elevation.
Why is this stuff so poorly built? We, as users, are paying for it. The quality of this stuff needs to be improved to some basic minimum professional standards.
Kevin McAllister
KM
1 answer to this question
