theArchitect Posted September 10, 2012 Share Posted September 10, 2012 Hello everyone, we are having a problem with the text on the dimensions. Somehow the text offset is different depending on what computer we open the drawing. Sometimes is okay and sometimes 0.5 points bigger. We are using VW 2009 Architect, any ideas? Thanks in advance Quote Link to comment
bc Posted September 10, 2012 Share Posted September 10, 2012 Could it simply be that there are different settings for the dimension standard or perhaps altogether different dimension standards chosen for use in the odd computers? Quote Link to comment
Kizza Posted September 10, 2012 Share Posted September 10, 2012 Same as BC, could be differing templates Less likely, what font type are you using? OT fonts can cause anomalies with dimensions, drawing labels etc. Quote Link to comment
VincentCuclair Posted September 11, 2012 Share Posted September 11, 2012 (edited) Create a dimension standard in one file/computer and import it to the other, they should look the same. Make sure you have the same font file for that font on both machines..... Edited September 11, 2012 by Vincent C Quote Link to comment
