ray isaacs Posted July 26, 2012 Share Posted July 26, 2012 i have created section viewports and placed them in design layers. now i want to print those sections. how can i get those same viewports onto a sheet layer? seems like an simple thing to do, but... cheers, ray Quote Link to comment
Christiaan Posted July 26, 2012 Share Posted July 26, 2012 (edited) Cut out the middle man. Instead of creating the section viewports on design layers create them on a sheet layers to begin with. If you don't want to do that for some reason then just create sheet layer viewports of your design layers. In either case there's an option to choose to put your viewport on a design layer or sheet layer when you create the viewports. Edited July 26, 2012 by Christiaan Quote Link to comment
ray isaacs Posted July 26, 2012 Author Share Posted July 26, 2012 christian, thanks for the quick reply. i created the design layer sections to be able to measure in actual scale rather than having to multiply when using the sheet layer. but, i may have to reconsider. i tried to create a sheet layer viewport from the design layer. but for some reason it isn't working. frankly, the section tool and i do not get along. cheers, ray Quote Link to comment
Dieter @ DWorks Posted July 26, 2012 Share Posted July 26, 2012 i created the design layer sections to be able to measure in actual scale rather than having to multiply when using the sheet layer. but, i may have to reconsider. You can measure in actual scale when going into the annotations of the section viewport. No need for calculating. Quote Link to comment
ray isaacs Posted July 26, 2012 Author Share Posted July 26, 2012 okay, now it's working: create sheet layer viewports of your design layers. apparently, the problem was due to update not being complete. ray Quote Link to comment
Christiaan Posted July 26, 2012 Share Posted July 26, 2012 Nevertheless I'd still recommend putting your section viewports directly on a sheet layer. As Dieter points out, you can measure off these by double-clicking into their Annotation layer first. Quote Link to comment
ray isaacs Posted July 29, 2012 Author Share Posted July 29, 2012 dieter and christian, thanks for explaining the annotations layer. you are right. that is the best way to view and work with a section. ray Quote Link to comment
