DTM Contour elevation text labels
to edit the site model text size directly, select the site model and set the text size directly through the Text Menu.
to make the change in the viewport you could select the viewport and in the Object Info Palette click on Advanced Properties and change the Text scaling to get an appropriate display. Be warned this applies to everything in the viewport so any properly sized text will be enlarged as well.
HTH,
Ion
