I am having alot of trouble getting some LiDAR data into VW. The base file is an elevation raster (unfortunately I do not have access to the raw point data), I have managed to create a multipoint file in GIS where each point has xyz data. This has then been exported to a DWG file (using the export to CAD funtion in ESRI ArcMap).
Tests in GIS show that the data is scaled and georeferenced correctly and has z values that I would expect. When I import this file into VW it is not to scale or georeferenced but the z values are correct. The first time I tried this it was scaled correctly but the z values were incorrect! I am now getting pretty confused as to what settings I shoud use. Any help would be very greatfully received.
Import settings are 2D/3D Conversion set to: 2D and 3D
Quackers
Hello,
This scale = 1:1
Set VW units to match is ticked
Import Points As: Loci
File consists of approx 30,000 points
VW verison 2012 sp1
Windows 7 32bit
2 answers to this question
