Assembly Posted October 22, 2011 Share Posted October 22, 2011 I found the settings to create these renders on Jon's Blog Here is the lighting set up for these images Thanks again Jon Quote Link to comment
willofmaine Posted October 22, 2011 Share Posted October 22, 2011 In "Lighting Options," which light does "Emitter Brightness" control? At first, looking at Jon's settings, it occurred to me that it might control the HDRI Background. But I find that I have to change the brightness of the HDRI Background itself, and that this "Emitter Brightness" control has no effect on it... Quote Link to comment
Assembly Posted October 22, 2011 Author Share Posted October 22, 2011 (edited) After a few tests I think for the light Emitter Setting to make a difference to a render you need a light PIO set as a Light Emitter. I guess the idea is to set the lights up as real world light emittance values. Then to use the Light Emitter % setting to fine tune the light/darkness of the render. Edited October 23, 2011 by Assembly Quote Link to comment
