TomCreation22 Posted July 12, 2011 Share Posted July 12, 2011 I've got a few questions about VW Designer, and I'm struggling to figure out the answers. 1. Is there a way to get the dynamic input to display dimensions based on the reference point? For example, if you reference the endpoint of a wall, and drag away from it to start another wall, or insert a window a specific distance away, the dynamic input thing always references the same point on the drawing rather than the point you originally referenced. Or am I doing it wrong? 2. Can you show wall components in a hatched section view? For example in ACA, you can section a double leaf brick wall and it'll show the detail of bricks, mortar and insulation. I know VW will do textured versions if using Renderworks, but I mean 2D style, hatched. 3. Is it possible to get shadows in a plan view when you're using wireframe? Reason being I would like to be able to show the normal detail for a plan view, wall components, hatching etc, but shadows as well. I can only seem to get shadows in a rendered view, which means I can't display hatching, and the cut plane is set above the wall openings so no windows/doors are shown. Thanks in advance! Quote Link to comment
CipesDesign Posted July 12, 2011 Share Posted July 12, 2011 It will be important to know what OS and VW's versions you are running... You can add these to your profile/signature by selecting the My stuff pulldown above... Quote Link to comment
TomCreation22 Posted July 13, 2011 Author Share Posted July 13, 2011 Thanks Peter, Updated as suggested. Quote Link to comment
