Are Scaleable 3D plants/ bushes available?
JohnS
Do you have Landmark with Renderworks? If so, you will find some files from XFrog in the Vectorworks Libraries which contain Image Props. These are symbols that consist of a plant image. You can change the size of these once you've put them onto the drawing.
If you are using the Place Plant tool, you can set up 2D/3D hybrid "Plants" that have a definition containing height and spread. These values will control the size of the 2D plan component and the 3D image prop embedded within the plant.
Hope that helps get you started.
If you DON'T have Landmark, you can still find some image prop files which have some plant material in them.
