preston bircher designs Posted March 4, 2011 Share Posted March 4, 2011 I'm trying to import my Label Legend Manager files from another show... VW Help says to use the "import" command within the Resource Browswer. Well, there isn't an "Import" command. Here's what it says: "Importing Label Legends from Another File Product: Spotlight Label legends from another Vectorworks Spotlight file can be imported into the current file. Import the Label Legends symbol folder contents from the original file into the new file with the Import command in the Resource Browser; place the legends into the Legends folder. The imported label legends are listed in the Label Legend Manager." So... how do I "Import Lable Legends from Another File"? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 4, 2011 Vectorworks, Inc Employee Share Posted March 4, 2011 In the resource browser open the file that contains the Label Legends. Select the label legend then right click on the Label Legend and then you should be given the option to import the label legend. This is the same process an any other document resource. Check out "Importing a Symbol or Symbol Folder" in the help. It's the same process for the label legends or the entire label legend folder. Quote Link to comment
preston bircher designs Posted March 4, 2011 Author Share Posted March 4, 2011 Kevin -- that had a slightly different read than the Help did -- plus a re-boot and amazingly, the "import" command was there -- and it worked. THANX! Quote Link to comment
