scheven_architect Posted February 18, 2011 Share Posted February 18, 2011 Hello, when i'm modelling for example a vase, is there a possibility to select certain faces or edges as i could in cinema 4d? greetings! Quote Link to comment
Benson Shaw Posted February 18, 2011 Share Posted February 18, 2011 Try the Extract Tool in the 3d Modeling Tool Set. It has modes for extracting a point, edge, surface or iso parametric object. A new, NURBS curve or surface is created by the tool and assigned to the Red Curves or Surfaces class. Original object is not edited. The contour tool can help this, too. Apply contours in desired direction and offset. Select pairs or groups of contours for loft or other surface creation. Orig object is not edited. -B Quote Link to comment
