scheven_architect
    136
Everything posted by scheven_architect
  1. Any possibiblity of moving the locus that seems to be off?
  2. How can you move a wall after inserting a window that is specified to take up the entire wall? If I try to grip the wall I select the window instead and drag it out of the wall.
  3. Nevermind, I just saw that the Dutch version is a piece of trash compared to the English one. English: 1 decent door and 1 decent window tool Dutch: 1 rubbish interior door tool and 2 rubbish exterior door/window tools screenshot of 1 of the exterior door/window tools
  4. This video doesn't show the door options I have in 2015.
  5. I can't customize an interior door after making it except for some minor changes in the info palet.
  6. Where can I find a sliding door?
  7. http://imgur.com/DF9raoy Any explanation how this could happen? Both walls are inserted exactly the same way. Also, why if i copy a window it's behaviour in the wall doesn't get copied?
  8. https://www.dropbox.com/s/ngj2pkt9cja8ehw/splay.vwx?dl=0 wall with a window that suffers from the problem
  9. I'm going to make my custom wall types starting from the ones standard in Vectorworks. That should solve it.
  10. Strange, after copy pasting them in an other file they are joined... So it seems related to my file.
  11. - These thin lines become thick when using component join tool. - They appear most of the time, sometimes they don't. - Custom wall = wall with components I 'made'. - Wall caps are off.
  12. They are custom made walls. When connections are made (even automatically) I still see a thin line where both walls meet. http://imgur.com/adU0dH5
  13. Why doesn't this happen automatically? Clicking dozens of walls is a painstaking task.
  14. Why don't walls merge nicely? And why if they do there is still a fine line? http://imgur.com/AUPlWW2 http://imgur.com/KrDqB5j
  15. http://imgur.com/HHYSfo3 Where should I find this? I guess the order is about the same as the english version. But I'm under the impression the dutch version looks very very basic compared to the English one.
  16. Whenever I try to align a wall to the grid, vectorworks uses the door as a reference. My grid is 5x5cm but the wall itself never gets aligned well... instead some point of the door aligns to the grid. And to be honest, grabbing to the grid is a disaster overall. Some settings I really should mark on or off?
  17. How do I copy a wall without copying the elements that are inserted in it?
  18. solved http://support.apple.com/kb/DL1572?viewlocale=en_US&locale=nl_BE
  19. I'm trying to install VWX 2015 but it keeps saying i need to install java, while I have installed it via the link provided by VWX 2015 itself... "There is no valid java version installed. This is required for installation of Vectorworks. Install Java from the opening website."
  20. Reshape handles on everything... Just started working with VWX professionally and because of the lack of this intuitive modeling it doesn't feel BIM at all. For exemple resizing windows is a real pain.
  21. I'm using the Dutch version, so nothing about english terms in help.
  22. If I want to make an undefined wall thicker it thickens out from the middle outwards. How can I move the axis of the wall to the out or inside?
  23. Don't know what you mean with splay but if I make a new window that situates behind the outer brick wall it happens again. Now they all appear to be orange.
  24. When I rotate a viewport the direction of the lines of patterns remain unchanged, can I make it so that they rotate with the viewport?
