cbd Posted February 14, 2011 Share Posted February 14, 2011 I was placing a circle over a line intersection and wanted to remove the fill to show the lines beneath. They are all in the none class and when entered I had the attribute fill to class style. I could not just change from Class to "None" I had to go to solid and then to none. I tried a rectangle with exactly the same results. I usually have the attributes set at Class for all the items and it has worked for quite a few years and versions but not 2011. Is this 2 step method normal now? Quote Link to comment
shr Posted February 15, 2011 Share Posted February 15, 2011 Having the same problem. All the time, won't let me change fills or lines for all kinds of objects, from/to class style or any other type (solid/none/hatch) Quote Link to comment
cbd Posted February 15, 2011 Author Share Posted February 15, 2011 i find that it will let me change from class to Solid and then to whatever I want but not directly from the class attribute. Maybe we have something turned on or off that didn't used to be....Anyone???? It definitely slows me down when I am used to one way of doing things and then have to add 2 or 3 steps to get the same result. Quote Link to comment
