Anthony Reilly Posted February 9, 2011 Share Posted February 9, 2011 I have imported a PDF file of a ground plan for a Fine Arts Renovation project at our school. I am drawing on top of this PDF and I keep accidentally shifting the position of the PDF layer. I figured out how to lock the layer, but I still end up selecting it inadvertently and am blocked from doing other modifications because this layer is selected. Is there a way I can draw on this layer and have it locked and not selectable? I created a "class" for the PDF but not a separate layer for it. Thanks Tony Quote Link to comment
CipesDesign Posted February 9, 2011 Share Posted February 9, 2011 Select PDF (or any object or objects) then use Modify>Lock... Quote Link to comment
Bob Holtzmann Posted February 9, 2011 Share Posted February 9, 2011 (edited) It's also possible to have the PDF on a scaled layer, and draw on a different layer set at the same scale. Just set the Layer Options to Show/Snap Others. This will prevent selecting the PDF image. I've also done this with Classes, but I like Layers better, because the PDF layer can then be put on the bottom of the layer stack. Edited February 9, 2011 by Bob-H Quote Link to comment
CipesDesign Posted February 9, 2011 Share Posted February 9, 2011 Bob, yes that would my preference as well. Thanks! Quote Link to comment
Anthony Reilly Posted February 11, 2011 Author Share Posted February 11, 2011 Thank you! It all worked out. Quote Link to comment
