bob cleaver
keynote trouble
Bob if you could add a signature would be great.
as for the 10 items. do you have 37 in the database? are all 37 being used on the drawing?
The file I am working on has 37 entries that are used on 2 layer sheets. The keynote numbers are in the annotation (one sheet is 50 scale, on sheet is 100 scale), the legend is on the 1:1 scale of each layer sheet.
Thank you for your help-
22" Imac 3.06 GHz Intel Core duo, 4 GB RAM, OSX 10.6.6, VW 2011 SP2
Thank you Bryan for your help
I started from scratch and added the database for the tree inventory I was working on. By starting over, the keynotes worked and all is fine.
Thank you again
FYI, I sent the file to tech support and they notified me they were working on the file but then never replied, one way or the other-
Good to hear Bob, sometimes they just get a glitch, with the data you had I felt it was best for you to start over. Sort of a bummer but welcome to technology.
I will play with this issue as I am working and see if I can find the cause, If I find or if you find lets post the bug so others will know what not to do.
