mdilday Posted December 13, 2004 Share Posted December 13, 2004 I have been trying to use "create a fillet surface" with "nurbs" object. After a I select the two items and then select create fillet surface a window appears asking for the radius. I have tried many different radius's and none have worked. I have tried following the examples on pg.s 10-14 and 10-15 of the Vectorworks version 10 users guide. [ 12-13-2004, 11:46 AM: Message edited by: mdilday ] Quote Link to comment
Vectorworks, Inc Employee Biplab Posted December 13, 2004 Vectorworks, Inc Employee Share Posted December 13, 2004 Select each of the NURBS surfaces and turn on the show normal flag in the object info palette. Make sure that the normal of the two surfaces are pointing in the same general direction - otherwise use Reverse Normal from OIP to achieve that. Quote Link to comment
mdilday Posted December 13, 2004 Author Share Posted December 13, 2004 Both red flags are pointing in the same direction. I also tried with the flags in the opposite direction without any success? [ 12-13-2004, 12:04 PM: Message edited by: mdilday ] Quote Link to comment
propstuff Posted December 18, 2004 Share Posted December 18, 2004 M: They should be not "in the same direction" as in both to the left, but "in the same direction" as in both towards the middle of the crease between those two curves. HTH N, Quote Link to comment
