The Hamma
Compare Fill Fore color
This is not working and I have no idea why, any help would be appreciated.
Procedure linecolor;
Var
cw: longint;
r,g,b: LONGINT;
h: handle;
BEGIN
GetFillFore(h, r,g,b);
if r,g,b =(0,0,255) then SetFillFore(h :255,255,255);
End;
Run (linecolor);
Another thing to note, the color space for RGB is not 0..255, but rather 0..65535. You can convert easily by multiplying each 0..255 value by 257.
As TBE points out, you need to get a handle to your object. The easiest one is FSActLayer. It can get much more complicated if you want your script to work off the active layer, but for most uses H := FSActLayer; will work.
Raymond
