BaP Posted October 13, 2010 Share Posted October 13, 2010 I've been having a problem with my lighting positions disappearing when I turn on the position summary. Either I get to see the lighting position or position summary. IS there a way to view both? Thanks Brian **using VW2008 and eval copy of VW2011 on pc's** Quote Link to comment
Vectorworks, Inc Employee klinzey Posted October 13, 2010 Vectorworks, Inc Employee Share Posted October 13, 2010 Your lighting positions are probably 3D only? In order for them to show correctly they should have a 2D element and a 3D element. The simplest way to deal with your existing positions is to edit the 2D portion of the symbol and draw the position in 2D. Once you have done this change a parameter in the lighting position object, causing it to regenerate, and you should see the position in 2D and 3D. Quote Link to comment
Cris with no H Posted October 17, 2010 Share Posted October 17, 2010 And be sure that your 2D portion is NOT assigned to Layer Plane. Quote Link to comment
