lucylou Posted July 16, 2010 Share Posted July 16, 2010 I want to make a section using a broken section line, but the instructions on the 'help' topics dont seem to work for me? I have tried making one straight section, then trying to edit the section line via the 2D re-shape tool but it doesnt seem to work? Is there a better way to do this? what am i doing wrong?! Thanks Quote Link to comment
mike m oz Posted July 16, 2010 Share Posted July 16, 2010 The section line works like all path objects: - Single click to start. - Single click at each change of direction. - Double click to finish. Note: - Section steps can only be at right angles to the direction of the section. - Sections can only look in one direction so if you want a change of view direction in the section you will need to use two separate partial sections. Quote Link to comment
