lucylou
174 -
Reputation
0 NeutralPersonal Information
Occupation
architectural assistant
Homepage
www.lcarchitects.co.uk
Location
UK
Excellent! thanks Jonathan! sorted! Thanks Lucy
Hi there am currently in the process of trying to convince the office to move over to 3D VW! we use 2D at the moment. We don't seem to have the renderworks camera view, is that because we don't have renderworks? (sounds like a silly question i know) Is there an alternative to setting up perspective views without using the camera tool? (we use VW2011 Architect, on macs) Help most appreciated. Thanks Lucy
Great! thanks! thought it might be as simple as that
Hi all I can't see my wall components in my section Viewport. I have the button 'show wall components on' and all classes are turned on.... Please help! I'm trying to convince my practice to go 3D VW and this isn't helping! Thanks Lucy
hi there I am having trouble with dimensions. Has been fine so far in other files, but I've just started to work on a new file and the dimensions keep going onto a class called 'site plan' even if i tell it to go on its own class. If I untick the box 'create dimensions in dimension class' then it they just go onto the active class. Is this a bug? has anyone else experienced this? Thanks Lucy VW11 SP5, mac
Perfect rDesign Thank you! I thought it should be something simple like that! thanks very much, Lucy
Of course. that makes sense! so are you saying that only the current version of VW works with the current version of Sketchup etc?
Really? my TWO year old version of VW (its only 2012 folks!) is not compatible with Sketch up? how ridiculous is that???! Any comments to make from VW people? I note they are keeping quiet...
Hi I am trying to import a sketch up model into VW. But nothing seems to happen when I go through the steps. Any ideas on whats going on? Thanks Lucy
Have noticed that the opacity tool only works if GDI+imaging is turned on... however, our font for our name/logo does not work if GDI+imaging is turned on. Why is this? I remember when VW2010 came out, one of the selling points was the opacity tool, but as yet have never been able to get it to work and always found a work around (ie just edit image in Photoshop) but recently I have persisted with finding why it doesn't work and realised the GDI+imaging button was turned off. But then our logo goes funny. Do we really have to chose between a dodgy looking logo OR the opacity tool functioning correctly as sold to us? or can we no longer have both?
Not sure if this is the answer, but I know a while back our text went all funny and we now have to make sure 'GDI + imaging' and 'Anti-aliasing' buttons are turned off. These can be found under Options > Preferences > Display. Worth a try? HTH
Thanks Monadnoc... I understand what you mean, but how do i find out whether they are located at 0,0? Thanks
Hi I should probably know this but I normally just use Top/Plan View (Ctrl 5) to view design layers in Plan and never noticed the significant difference before... When I view in Top view, my 3d trees are in a different location to my 2d trees when viewed in Top/Plan view. (see attached screen shots) I noticed it when setting up a camera shot and wondered why the trees were in front of the camera when actually they should be behind/to the side of it. Any ideas?! Thanks
I'm not entirely sure then. I copied the site model onto a new layer in my GA drawing file and it is still changing. Ok... think i've just cracked it. I had created a site modifier as a base/platform to the houses and just realised i hadnt copied that across. Apologies! Thanks for your help though!
