ChrisW Posted July 14, 2010 Share Posted July 14, 2010 I have a curved wall with a couple of objects placed in specific locations. Is there a way to generate a flattened elevation viewport from a 3d model to dimension their exact locations? Quote Link to comment
Jonathan Pickup Posted July 14, 2010 Share Posted July 14, 2010 It is a bit of a workaround, but it is possible. use the Extract tool to extract the surface of the round wall. this will create a nurbs curve that has the holes in it, if the doors and windows correctly installed. you can then use the unfold surfaces command to unfold the surface to a 2D object. Quote Link to comment
