James Russell Posted June 23, 2010 Share Posted June 23, 2010 Hey all, Just having a play with a label legend I have created for some of my lamps. There are three fields shown, a lamp ID letter, ID number, and unit number. As you can see in the attached image, when the lamp is rotated with the label to the right of the lamp the text reads as is should, eg B2 although when rotated to the left it causes it to be read opposite, eg 1C. Any ideas if the direction of text can be locked to always be relative to the object even if this means flipping upside down? Cheers, James Quote Link to comment
michaelk Posted June 23, 2010 Share Posted June 23, 2010 If I understand correctly what you are trying to do, this should do it: Preferences > Display Tab > UNcheck "Adjust flipped text" hth michaelk Quote Link to comment
James Russell Posted June 23, 2010 Author Share Posted June 23, 2010 Thanks Michael that's done the trick alright. So that's only programs specific yeah? If I sent this document to someone else the orientation will change? J Quote Link to comment
michaelk Posted June 23, 2010 Share Posted June 23, 2010 James I believe that's correct. It's an application preference - not a document preference. Quote Link to comment
James Russell Posted June 23, 2010 Author Share Posted June 23, 2010 That'll do me for now. Thanks Michael. Quote Link to comment
