Assembly Posted June 11, 2010 Share Posted June 11, 2010 (edited) The result of this function, inside a PIO creates and 'exploded' bunch of nurb surfaces. Using the menu extrude along a path creates a solid extrude. Major difference. Who knows how to make an exturde along a path that remains and extrude thus allowing further add / subtract functions to happen?. Edited June 11, 2010 by Assembly Quote Link to comment
Pat Stanford Posted June 11, 2010 Share Posted June 11, 2010 Try using MyEAPHandle := CreateCustomObjectPath('Extrude Along Path',MyPathH,MyProfileH); instead. Quote Link to comment
Guest Mark Flamer Posted July 29, 2010 Share Posted July 29, 2010 I am also trying to create a path PIO that is then modified internaly using Add & Subtract solids. I have tried MyEAPHandle := CreateCustomObjectPath('Extrude Along Path',MyPathH,MyProfileH); as suggested above. I still cannot get a subtraction to work. Any other Ideas? Thanks. Quote Link to comment
Guest Mark Flamer Posted July 30, 2010 Share Posted July 30, 2010 I will make my question more straight forward. Does anyone know of any way to get a solid out of an extrude along path that could be further manipulated with Boolean operations? This seems like it would be a pretty common request. Thanks alot. Quote Link to comment
Guest Mark Flamer Posted July 31, 2010 Share Posted July 31, 2010 I've realized that the problem with using MyEAPHandle := CreateCustomObjectPath('Extrude Along Path',MyPathH,MyProfileH); and then trying to perform solid operations on it boils down to the fact that CreateCustomObjectPath creates a seperate PIO that is not actually created untill the original script is completed. And because the subobject needs to be re-created everytime the object is redrawn, its never available! Any insight into this situation would be greatly appreciated. Thanks. Quote Link to comment
