CreateExtrudeAlongPath
The result of this function, inside a PIO creates and 'exploded' bunch of nurb surfaces.
Using the menu extrude along a path creates a solid extrude.
Major difference.
Who knows how to make an exturde along a path that remains and extrude thus allowing further add / subtract functions to happen?.
Edited by Assembly
  • 1 month later...
Guest Mark Flamer
I am also trying to create a path PIO that is then modified internaly using Add & Subtract solids. I have tried
MyEAPHandle := CreateCustomObjectPath('Extrude Along Path',MyPathH,MyProfileH);
as suggested above. I still cannot get a subtraction to work. Any other Ideas? Thanks.
Guest Mark Flamer
I will make my question more straight forward. Does anyone know of any way to get a solid out of an extrude along path that could be further manipulated with Boolean operations? This seems like it would be a pretty common request. Thanks alot.
Guest Mark Flamer
I've realized that the problem with using
and then trying to perform solid operations on it boils down to the fact that CreateCustomObjectPath creates a seperate PIO that is not actually created untill the original script is completed. And because the subobject needs to be re-created everytime the object is redrawn, its never available! Any insight into this situation would be greatly appreciated. Thanks.
