Paul P Posted May 5, 2010 Share Posted May 5, 2010 I have started the exercise, VWA Tutorial Manual (J Pickup) When I go through the section to create the site model the 3d loci do not appear. I have reduced this to a simple exercise and still no result. I have: 1 created three contours in a file with just one design layer. they are polygons of five vertices each, confirmed in object info. 2)go to AEC survey input/ 2D polys to 3D contours 3) dialogue box: start elevation 1000 interval 1000 create 3D loci OK 4) set elevation (as input previously) press next/next/next " would you like to delete your original 2D polygons?" Yes the page is blank why can I not see or why aren't there any (15) 3D loci visible on the page please? I also tried to place 3D loci using the 3D loci tool, randomly on the page to no avail. What am I missing? thanks Paul Quote Link to comment
Jonathan Pickup Posted May 6, 2010 Share Posted May 6, 2010 send me the file and let me see it. check your class options, show/snap/modify others Quote Link to comment
Jonathan Pickup Posted May 6, 2010 Share Posted May 6, 2010 what about a Vectorworks preference... Tools > Options > Vectorworks Preferences > Display > Display 3D Loci.... Quote Link to comment
Paul P Posted May 6, 2010 Author Share Posted May 6, 2010 Thank you Jonathon, the 3D loci were turned off in the preferences. I have progressed with the model but the contours arent showing in the terrain model. I seem to have the settings correct. There is a loci on visible on the 3D model that shows as property line in object info. I cant seem to show the contours? suggestions appreciated thank you Paul Quote Link to comment
