joerg Posted February 26, 2010 Share Posted February 26, 2010 having 2 layers created a viewport and set the top layer in the viewport layervisibilties to grey ind rendered beautyfully transparent. But in 2010 it doesn't!! am i missing something? or is this a bug? This was ( or hopefully is a very nice feature!) Quote Link to comment
Pat Stanford Posted February 26, 2010 Share Posted February 26, 2010 Check your Preference and make sure you have Quartz Imaging turned on. I think this is required for transparency effects. Quote Link to comment
joerg Posted February 26, 2010 Author Share Posted February 26, 2010 Thanks Pat, i had Quarzimaging turned on ...! Quote Link to comment
Pat Stanford Posted February 26, 2010 Share Posted February 26, 2010 Your right. It seems to be broken in VW2010. If you use a Unified View and render in OpenGL, the grey layers are translucent. If you do the same thing in a viewport, they are opaque. Can you use Fast Renderworks instead? Slower, but at least it does the transparency. Funny, but OpenGL does work in Design Layer Viewports. But when you make a Sheet Layer Viewport of the layer with the Design Layer Viewport it does not work. Quote Link to comment
joerg Posted February 26, 2010 Author Share Posted February 26, 2010 Thanks again. i might report it as a bug than! Hey i paid for an upgrade not a downgrade ;-) There are probably workarrounds but i liked the siplicity of it! And i like the look and speed of openGL. It has a bit of the Sketchup look, still a drawing not too realistic!!! cheers Joerg Quote Link to comment
