running two diferent versions
kma
Running two versions is pretty standard stuff, however file formats are quite different (and between 2010 and vw12 you will find the file extension different) so files will need to be exported each time to the older version. This also means that some functions may not translate very well, so don't expect full 360'ing.
Personally I would not recommend using different versions of VW for the same project, but sometime it is unavoidable.
