Cursor Offset
I have just installed VW2009 w/ SP4 onto my laptop with Vista 32-bit. When my cursor is in the drawing area the point where my cursor is visually is above and to the right of where things are drawn or captured when I click. Example: I put my cursor at the top right corner of a rectangle with the line tool active. When I click and draw, the line is drawn below and to the left of where my cursor is. I don't have snap to grid active. Any thoughts?
  • 1 month later...
  • 1 month later...
Hi
My case is exactly the same as the post by sancho1981 above.
Im using VW2009 with Vista-32bit
No contraints are on.
And yet when you go to draw a line (or do anything) the line is drawn 5mm below the cursor.
Finding it tricky to upload screen shot at the moment. :confused:
But anyhelp would be greatly appreciated.
Well, below the x of the cursor is a very faint grey square which is what appears to be the real drawing point.
When i first installed the programme all was fine, and all the endpoints of lines would high light when you went over them, now that doesnt happen.
But yes, if i wanted to pick up a line i had drawn and move it. I would have to click on it with the faint grey square 5mm below the cursor. The cursor marked x is useless....
Very frustrating...
Could this be something to do with endpoint settings?
