ajpen Posted September 21, 2009 Share Posted September 21, 2009 Problem: Spotlight Instrument with attached Label Legend displays correctly, with numbers on top of the fixture. When the fixture is rotated using "Set 3D Orientation" in the OIP, the text label gets sent "behind" the 2D symbol. The grab handle is visible when the fixture is selected, and the label can be moved outside of the 2D symbol where it then becomes visible. However moving it back to the 2D symbol slips it "under" that symbol. If the symbol is edited to make the fill "none" then it does not cover up the truss where it is placed. i would like to keep the fixture plan symbol "on top" of the truss. If the "Set 3D Orientation" box is unchecked, the label reappears on top of the fixture. HELP!?!?! Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 21, 2009 Vectorworks, Inc Employee Share Posted September 21, 2009 This is a bug that has been fixed. I thknk it was fixed in 2009. Quote Link to comment
