carpenter1234
vector script: replace font type?
is there a possibility to replace any font type in one drawing with a specified new one in a batch mode without selecting each one?
font size should not be touched.problem is there are lots of text in groups , symbols and layout areas in my drawing, so i can't selct them all at once(and i don't want to cycle through these myriads of objects).
Edited by carpenter1234
Did you assign a unique Class to the text ?
DSelectAll; SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (C='FontClassTest'));;
If ,yes, then use the selection by Class to make a global change. If not then you will need to select by the FontID:
DSelectAll; SelectObj(INSYMBOL & INOBJECT & INVIEWPORT & (FOT='Arial'));
ok, i treid the global text attributes, it works, but it won't change in symbols and in layout areas, neither in groups.
would a vectorscript be capable of that spcific task anyway?
The script to use includes "INSYMBOL & INOBJECT & INVIEWPORT" ... just replace the 'Arial' with your FontName.
sorry to say so, but it won't select text in groups, symbols and viewports. only "real" textobjects.
