George Cocea
Content Count
58 -
Community Reputation
0 NeutralAbout George Cocea
Rank
Apprentice
Personal Information
Occupation
Consultant
Location
Los Angeles, CA
layer plane, working plane, screen plane, 3d
George Cocea replied to Joel Riehl's topic in Architecture
www.vectordepot.com/plug-ins/ offers the "plane mode" pio which will convert globally all objects (no selection required) to either layer plane or screen plane. -
Here is a solution (via QuicKeys) to place/assign a VW menu command on a QuicKeys toolbar and execute the command with a single mouse click. For more info see: ? attached 01 VW screen example (this is what my current setup is) ? attached 02 VW qKeys captures ? QuicKeys website: http://www.startly.com/products/quickeys/mac/4/ Other tools & tips 1. Bluetooth keypad I added this keypad, whose keys I programmed assigned (via QuicKeys) for ease of entering dimensions with my left hand. If you prefer a streamlined values (including ft & in markers) input you may consider this keypad For more info see: ? http://eshop.macsales.com/item/Cropmark/8337/ ? attached 03 bluetooth keypad 2. Arch calculator It is helpful when I need quick calcs whose values are stored on tape. The input keys and tape can be minimized for the app to occupy a small footprint on screen, as it can stay on top of all apps. For more info see: ? 01 VW screen example ? http://www.cast-db.com/archCalc/ 3. iBiz for time tracking & billing I use this app which fits my needs. If you are looking for such an app you may want to consider it. For more info see: ? attached 04 iBiz captures ? http://www.iggsoftware.com/ibiz/index.php 4. Papers - for a digital reference library Papers offers a clean interface of document organization (currently PDF.) I use it to organize my VW tips, software & hardware manuals, Building code references etc. I used to have the setup in finder, however the lack of quick search & view & navigation & the distraction of the rest of the items in the finder was an incentive to acquire Papers. The next version coming out in the next several days looks more promising. For more info: ? attached 05 Papers capture ? http://www.mekentosj.com/papers/ I hope the above answers some questions for other fellow vectorworkers. George C.
Try to increase the "max text width" value in the OIP.
I read in an earlier post that someone reported this bug. My answer to bugs is:I HOPE that they will be fixed (squashed.) AFAIK, there is no public information about the number of bugs nor about their outcome.
Hi Farookey, You are welcome. I am glad to see that it solved part of your problem, and that Matt polished it up for you.
I get the same behavior with the section line pio. It seems to be a bug. As a workaround, I place reference marker pios in place of the section line pio on a separate layer, next I place the section line pios in a separate class which I turn off.
Here is a simple crude vs (sequence of commands) that comes close to what you described: DoMenuTextByName('print', 0); Message('Next, Save as PDF'); DoMenuTextByName('print', 0); clrmessage; This set of commands will call the the print command twice. The first time the user can print the file, next there will be a message displayed on screen "Next, Save as PDF" which you can change per your needs. At the second print dialog the user can save the file as PDF. You can copy the vs commands above and create a vs command Tools/Scripts/VectorScript Plug-in Editor... which you could label "Print", or "Print & PDF", next edit the workspace (or a copy of ) Tools/Workspaces/Workspace Editor remove the Print command (or not), and add the new "Print & PDF" command in the File menu. BTW, I am not a vectorscript programmer beyond a few command lines.
One way of doing this is via a worksheet. After you create a pio (i.e., door, window, etc) report, or schedule worksheet you can insert additional 'record(s)'.'field(s)' in a new column. After that, it's pretty much typical worksheet interface; you enter a new value in the worksheet cell(s) and the pio updates automatically. You can get all the pio fields available by using a script wrote by Pat Stanford (see link below for source) which creates a new worksheet of all the fields associated with the selected pio. http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=115054&Searchpage=1&Main=23203&Words=GetPIORecordFields&Search=true#Post115054 For your inquiry Exterior trim class for windows the database input is ='Window'.'ExtSillTrimClass' HTH, George
Miguel, I will try your suggestion. Meanwhile, I found a workaround for my immediate need: I can select "Create Redline Status WS" menu command and it will open the worksheet if it exists in the resource browser. Thank You
I would like to find out if there is a vs command to open a specified worksheet. I had no success with the current VS functions reference for such a task. Specifically, I want to create a simple vs that will open the Redlines Status Report worksheet. Thank you, George
I recall this option from a recent experience setting up some simple scripts via the Tools/Custom Tool Attribute menu command. Select your snap options, go to Tools/Custom Tool Attribute... and select only the "smart cursor setting" option, click OK and the script will be created. BTW, I tested the snap options scripts and it works on my VW 2009 SP5 version. You can do this step for any snap configuration you want; thereafter you can copy the script (via the resource browser) , create a menu command and assign it a keyboard shortcut in the workspace editor.
Keystrokes & Actions Recorder Functionality
George Cocea replied to islandmon's question in Wishlist - Feature and Content Requests
How about QuicKeys meanwhile. http://startly.com/ -
Another option is to create a symbol out of the circle and select the option to convert to group.
vector script: replace font type?
George Cocea replied to carpenter1234's topic in General Discussion
I use Global Text Attributes by Software Customization Services, Inc. I recall that a demo is available. http://scs-inc.us/default.php?page=products&subPage=Products/Global%20Text%20Attributes/Default Best, George -
Viewport > advanced properties > black & white only - preference
George Cocea replied to George Cocea's topic in Architecture
Pat, It worked ! Thank you, George
