VWUser2335 Posted July 2, 2009 Share Posted July 2, 2009 How do you turn dimension markers into dots where they intersect column center lines? Or is this old-school convention that went out of fashion with CAD? Quote Link to comment
rDesign Posted July 3, 2009 Share Posted July 3, 2009 You'd have to create a second custom Dimension Standard to be used just for the gridline dimensions. On the Document Preferences settings, click on 'Custom', create a new Dim Standard and click 'Edit' then change the Linear Marker setting to the solid dot or create a custom one if that doesn't suit your needs. Regards, Tim Quote Link to comment
