Doug L 0 Posted June 1, 2009 Why does data in a plant report chart not update on the drawing? A ground cover (Pachysandra terminalis) is listed in the perennial category (by default per the Landmark Plant Database), but it?s more commonly known and used as a ground cover here. I want it to be grouped in the plant report chart under Ground Covers instead of Perennials. Here is what I?ve tried: 1. In the Landmark Plant Database, Sort by ?Used in Project? 2. Find the plant, change its Category to ground cover. 3. Select File menu/Create Vectorworks Plant List. 4. In Vectorworks, select Place Plant Preferences, Edit Plant Definition. 5. Select Get Plant Data, select the Plant List for the project 6. Select Plant List Display name. Now in the Get Plant Data window, the field category is now listed as Ground Cover. 7. Double Click the Plant Report Chart. 8. Select Recalculate. However, the Category for that one plant still says Perennial. I?ve also tried to the above to edit plant comments in the Plant List Report and it doesn?t update either. This procedure used to work. One thing different this time is that custom Plant List Report I?m using has been edited to group plant categories together (trees, shrubs, groundcovers, etc). Also tried: In the Plant List Report, turn on Database Headers, copy ?shrubs? to the bottom of the list, go through the Set Criteria (Record/Plant Record, and Field Value/Category = ground cover). However, Pachysandra is still not listed under Ground Cover. Also tried: Delete the entire Plant List Report, and reimport it from the Resource Browser Still no change. Quote Share this post Link to post
Doug L 0 Posted June 1, 2009 A bug or memory problem? File is now 105 MB with 4 other consultant?s design reference layers. The plant tools started acting strange, so I quit the program and restarted it. After I selected Recalculate in the plant list report, 402 Pachysandra are now listed under Ground Covers! .......But 231 Pachysandra remain listed under Perennials! There appears to be only 402 on the planting plan (created by the landscape areas tool). Quote Share this post Link to post
Ozzie 17 Posted June 2, 2009 Doug, How you doing? Try this in the Landscape Area for the plants not totalling properly - Edit the Plant - see if that changes it Problem is if you have Pachysandra in different Landscape Areas you have to Edit them all - I think Quote Share this post Link to post
IanH 0 Posted June 2, 2009 I would suggest updating to SP3. The Landscape tool has been very buggy from the start and subsequent updates have made it better (although some broke functionality too) but I still believe that it gave incorrect results in SP2. The problem areas were down to counting plants and how percentages added up - possibly all linked to incorrect area calculation. Quote Share this post Link to post
