How do I save to .vss?
MaxStudio
A vss file is is Plug-in Command. To create one, go to the VectorScript Plug-in Editor (Toosl:Scripts:VectorScript Plug-in Editor). Click on the New button on the Right side and then make the type Command.
A new VSS file will be saved in your user data file. The dialog box where you select the type will show you the full path to the file.
