wvancampen Posted January 16, 2009 Share Posted January 16, 2009 Please confirm that door/window ID bubble shapes do not change scale if you change the scale of the viewport they appear in. Eg, I have a design layer plan created at 1/4" scale. On a sheet layer I want to show that plan in a viewport at 1/2" scale. All the ID bubble shapes and their labels appear twice as big--which makes sense, but I want them to appear at their original size. So in Advanced Viewport Properties I set Text Scale to .5. The ID labels change back to their original size but the shapes do not and remain and their enlarged size. How do I reduce the shapes' size? Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted January 16, 2009 Vectorworks, Inc Employee Share Posted January 16, 2009 Here is a suggestion. I have run into the same aspect on some of my projects. Until VW presents the opportunity to assign a class to ID text and another class to the bubble the temporal work around is this: 1- Assign a class to the object ID ( look into object info > data > ID class ) 2 - Your objects should present the ID text but select no bubbles, just plain text for ID 3 - Create your own symbol bubbles, one for 1/4" and other for 1/2", put them in classes 4 - On your final sheet, 1/4" viewports may show your symbol bubbles 5- Use your viewports advance properties and change the text hgts as needed. At a 1/2" hide your bubbles and place new one as annotations. I'll dig more into this and I'll see if we can find a better solution. ---------------------------- Luis M Ruiz Architectural Industry Specialist NNA Quote Link to comment
