blimey Posted November 14, 2008 Share Posted November 14, 2008 Hi, I'm experimenting a very strange phenomenon : I've got PIO windows and doors inserted in walls. Some of them behave normally, others have the door sheet or window rotated at 90?... It's totally bizarr. And I realized the problem comes from the wall. So the same window would be normal in some wall and then if inserted into a "contaminated" wall it will start to behave strangely en wont retrun to normal once reinserted into the other walls... Any body as a clue of why it does so? Is there any parameters I should set up or is this a bug??? Here is a view of the strange doors and windows Quote Link to comment
blimey Posted November 14, 2008 Author Share Posted November 14, 2008 Does anyone have a clue about this? the phenomenon is linked with the orientation and happens only in one direction (all the windows that are horizontal) If I make a referenced viewport of the drawing and rotate the viewport by 90? the phenomenom switches so that it happens still to the windows in horizontal walls... and the rotated wall (now in the vertical direction) contain windows that look fine... Quote Link to comment
blimey Posted November 14, 2008 Author Share Posted November 14, 2008 Now i'm sure this is a bug!!! and the work around is : make a viewport and rotate it by 0,05? for exemple so that no walls stay horizontal or vertical (sometime the phenomenon happens on vertical walls othertime on horizontal). As soon as the walls are not straight the windows and doors come back to normal, 0?05? is not too visible... still it's really annoying. Quote Link to comment
Jeffrey W Ouellette Posted November 14, 2008 Share Posted November 14, 2008 Can't say I've seen this yet. Could you please file a bug and submit the file? http://www.nemetschek.net/support/bugsubmit.php Quote Link to comment
LMS Posted November 14, 2008 Share Posted November 14, 2008 NNA quality control does not include checking to see if windows work properly in walls? Quote Link to comment
Jeffrey W Ouellette Posted November 15, 2008 Share Posted November 15, 2008 No. It seems very odd. It may be limited to just this case. IT happens. Sometimes files develop anomalies like this. It is good to see what the anomalies are and see if they can be reproduced, fixed and avoided again. Quote Link to comment
blimey Posted November 15, 2008 Author Share Posted November 15, 2008 Ok. I'm uploading the file here : http:///b612architectes.com/vw2009/0804 - BRUYN_PL100_BATC-test3.vwx. It happens not only in one file but in quite a few of them. some of the initial file were drawn in 12.5... so i wondered whether it was linked with conversion. yet we've copy pasted the wall into "clean" VW2009 files and the "phenomenon" was still there... that's why we saw it as a kind of "contamination"... well these are all not very scientific... We were just happy to find a work around without needing to redraw the whole thing... Quote Link to comment
blimey Posted November 15, 2008 Author Share Posted November 15, 2008 oups sorry didn't pay attention to the link... will do that Quote Link to comment
blimey Posted November 15, 2008 Author Share Posted November 15, 2008 hmm... just went on the bug submit page : they say one should explain STEP BY STEP what's leading to the bug... I've got no idea as it just does not happen all the time, but sometime in some walls... Quote Link to comment
