XOP15 Posted November 9, 2008 Share Posted November 9, 2008 Hi Guys, Does anyone know if it is possible to extrude a TT Font. I am trying to create a "neon" style sign. Any help greatly received. Cheers Quote Link to comment
CipesDesign Posted November 9, 2008 Share Posted November 9, 2008 Yes, if you have the "True Type to Polyline" command (not sure whether this is part of fundamentals package...). First create the text, then run the command, then extrude. Quote Link to comment
XOP15 Posted November 9, 2008 Author Share Posted November 9, 2008 Hi There, Thanks for your reply, OK, yes i have the 'Truetype to Polylines' command in the drop down text menu, I am able to execute this command. I just cant extrude it. I just get the error message "there were objects selected that were locked or are illegal in extrudes and sweeps. They have been deselected" Any ideas ? Cheers, Dave. Quote Link to comment
CipesDesign Posted November 10, 2008 Share Posted November 10, 2008 If I remember correctly, the result of the TT to Poly command is a GROUP (which is not an extrudable object type). Try Ungrouping, then select all (of the objects that were grouped) then extrude... Quote Link to comment
td4stage Posted November 10, 2008 Share Posted November 10, 2008 I just happened to have VW open and tried this...Peter's directions are correct! Really... as if there was a doubt! :-) Quote Link to comment
XOP15 Posted November 10, 2008 Author Share Posted November 10, 2008 Hi Peter, BINGO ! got it, many many thanks, you were correct, I just needed to un-group the text and extrude away. All Good, Thanks once again, Dave. Quote Link to comment
cad@sggsa Posted December 9, 2008 Share Posted December 9, 2008 Thanks Guys Just what I was looking for. Quote Link to comment
DigitalGaz Posted January 31, 2014 Share Posted January 31, 2014 Not sure if it's correct to comment on a solved post. Is there a solution for text that has been imported from a .DWG file that was created in Illustrator??? (Custom Text for a Logo) Quote Link to comment
CipesDesign Posted January 31, 2014 Share Posted January 31, 2014 If the "custom text" is actually a VW's Text Object, and if the Font Type is acceptable (TT and some others) then the above procedure should work. If the "text" is actually something else? let us know what (select it and see what it is called in the Object Info Palette [OIP]). Quote Link to comment
DigitalGaz Posted February 4, 2014 Share Posted February 4, 2014 The Custom text is a logo that has been drawn and created in Illustrator. It has then been saved as a .dwg and the imported to VW. OIP denotes that it is a 3D symbol. The logo looks as if it could be extruded as when switching drop Top Down to an Isometric view the shape angles as it should. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 4, 2014 Vectorworks, Inc Employee Share Posted February 4, 2014 If they have come in as symbols, you can edit the symbol to get at the geometry, depending on whether it is 2D or 3D you'll either TT to Polyline and then extrude as described above, or simply go right to the extrusion. You won't be able to extrude the symbols directly from the outside. Quote Link to comment
