Daryl Wood
Standard naming error
I cannot get to "document settings/Standard Naming..." without this error:
"A VectorScript error has occurred. Refer to the file "Error Output" for a further explanation.
And the output explanation is:
"Error: _1196 _34 - Array ALLOCATE end < start: _57 s/been made.must first call GetEvent to invoke appropriate..."
I just need to change the class of a joist object and cannot seem to do it. Was trying to get to the standard naming dialog and disable auto classing to see if that would work.
Any ideas appreciated.
I experineced issues using standard naming.
The circumstances were creating sheets and viewports using standard naming, then deleting them.
When I tried to recreate them later, the file became corrupt.
It was sent to NNA via bug submit.
Subsequently, I have avoided this problem by not using standard naming.
Edited by brudgers
Daryl,
Please submit a bug, with the file in question, if it is only one particular file this is happening with. Otherwise, is sounds like a Tech Support issue that requires more in-depth investigation.
