johncruet Posted August 25, 2008 Share Posted August 25, 2008 I just upgraded to OS 10.5. I downloaded and installed the 12.5.3 which was supposed to fix compatibility issues with Leopard. The door and window placement tools are not working properly. I place a door into a wall, as usual, and I lose the door and the doorswing in Plan view. When I place the window, I lose the window sash view in plan view. In both cases, only the trim and jambs show, and the doors and windows do show up in 3D views. Does anyone have any suggestions as to what might be causing this problem? Quote Link to comment
gmm18 Posted August 25, 2008 Share Posted August 25, 2008 Check for a class called "sills." It is a bug that creates this class, the trick is to just be sure you have this class turned "visible." You can delete the class, but it will just regenerate again next time you place a door... Quote Link to comment
johncruet Posted August 25, 2008 Author Share Posted August 25, 2008 Check for a class called "sills." It is a bug that creates this class, the trick is to just be sure you have this class turned "visible." You can delete the class, but it will just regenerate again next time you place a door... Thanks- that corrected the problem. Quote Link to comment
