CS1 Posted July 30, 2008 Share Posted July 30, 2008 (edited) In a 3D view why cant the mouse snap to the corners (points) of an extrusion, I can snap to the "centre", "object" etc but not the corners. (In the constraints I have "3d snapping" > "snap to edge points" ticked) Edited July 30, 2008 by CS1 Quote Link to comment
dovermyer Posted July 31, 2008 Share Posted July 31, 2008 I'd be interested to know this as well. Maybe VW can't & it's just not talked about...it would explain why there's been 24 views & I'm the 1st reply. Quote Link to comment
Benson Shaw Posted August 1, 2008 Share Posted August 1, 2008 Snap to corners works well for extrudes and other 3d objects in fly over views and standard 3d views, rendered and unrendered. The cursor cue says "Object" at the corners. Same in previous versions of VW. Try toggling the Constrain Working Plane and Constrain. It affects the snap ability for upper and lower corners of extrudes. With one or both constraints enabled, the corner snaps may not work. Or are you describing something else. -B Quote Link to comment
