kelrock Posted July 21, 2008 Share Posted July 21, 2008 (edited) I have run into another issue that I can not find a fix for. I have created drawing with multiple truss positions. Some of these trusses cross another. These truss positions are are each in their own class. As I attach a fixture to a truss, the position shows up in the object info window as it should. The problem happens when a fixture is attached with one truss position that is crossing another. The fixture will change positions if it touches a different position. This even happens when I turn off the unwanted position class. I try to type in the correct position in the object info window, but it reverts back to where it seem to think it should be. The end result is that the instrument schedule is incorrect. Any ideas? Edited July 21, 2008 by kelrock Quote Link to comment
Cris with no H Posted August 8, 2008 Share Posted August 8, 2008 Group position and its instruments. Quote Link to comment
