brudgers Posted June 26, 2008 Share Posted June 26, 2008 What exactly does it mean when a parameter has "__NNA_DO_NOT_CHANGE" as it's alternate name? Does this mean that NNA worker bees should not change it, or that the user should not? If the latter, what are the likely consequences of changing some of the default window parameters, particularly class settings? Quote Link to comment
gmm18 Posted June 26, 2008 Share Posted June 26, 2008 I thought that just means not to change the alternate name itself, I wonder now though if it means as you suggest, not to change ANY of the defaults in that parameter row. ???? Quote Link to comment
D Wood Posted June 27, 2008 Share Posted June 27, 2008 I get this in the OIP sometimes - it's usually an old door or window, maybe from a previous version that I've carried over. Usually changing another parameter seems to refresh the whole object info and the parameter corrects itself. Quote Link to comment
maarten. Posted June 27, 2008 Share Posted June 27, 2008 If the latter, what are the likely consequences of changing some of the default window parameters, particularly class settings? When you change those parameters, the classes will change from "none" to the ones you fill in (not sure about all though, only have tried one)... BUT it will not be visible in the dialog, there it will still say "none" cause it's not programmed that way (i tried it out (i don't use that pio anyway, so it wouldn't matter if it wouldn't work anymore)). On a side note: I personally wouldn't start messing around and changing other one's pio's, especially not when they are locked and when you have to use them on a daily base. If NNA don't want you to change it, they probable have a reason for that. Quote Link to comment
brudgers Posted June 27, 2008 Author Share Posted June 27, 2008 Thanks Maarten. But my choices are to change the class in the PIO or manually change it in every project or to create custom symbols and live without the interface advantages offered by PIO's (it's very unlikely I will write my own PIO's). For example, the window ID tag defaults to layer "0" - which sucks. The only good reason I can think of for NNA not wanting it to change is because the code is *****. Quote Link to comment
