bclydeb Posted June 13, 2008 Share Posted June 13, 2008 Strange classes have appeared in our file(s). They begin with NNA# and have sequential numbers e.g NNA#4_Wall-Component-Ext Finish. And they titles (e.g. Wall-Component-Ext Finish) mimic the class names originally set up in the file. Other problems are cropping up like stairs disappearing or not rendering/ being visible in 3D. Our backups show the same corruption(s). We have three months of work going down the drain here!!! Is our Vectorworks (Designer Rederworks, 2008 SP2 [build 83338]) corrupt or the file? Quote Link to comment
Christiaan Posted June 13, 2008 Share Posted June 13, 2008 Strange classes have appeared in our file(s). They begin with NNA# and have sequential numbers e.g NNA#4_Wall-Component-Ext Finish. And they titles (e.g. Wall-Component-Ext Finish) mimic the class names originally set up in the file. We're getting that too. Presumably a problem with Workgroup References and Design Layer Viewports. Although it doesn't appear to be causing us any critical problems. Quote Link to comment
bclydeb Posted June 16, 2008 Author Share Posted June 16, 2008 Christian, Thanks for your insight. I have experimented to verify that the strange classes were not affecting the stairs. They appear to be separate issues. I notice in other places in the forums there are quite a few of us frustrated with the stair tool. It works but not really! I have also discovered that deleting the offending classes clears up the too many classes to scroll through issue. The file is free from the extra NNA#? classes and they have not returned. (Yet!) Again, thanks for your insight. Quote Link to comment
Jeffrey W Ouellette Posted June 17, 2008 Share Posted June 17, 2008 Neither of you should be seeing these classes. They are a part of the (Workgroup) Referencing scheme. This sounds like a corruption. Please file bugs and get the files to NNA. http://www.nemetschek.net/support/bugsubmit.php Quote Link to comment
Guest Tolu Posted June 18, 2008 Share Posted June 18, 2008 bclydeb, Make sure you are using the latest service pack, SP3(88670). Quote Link to comment
