Jodyb17 Posted April 21, 2008 Share Posted April 21, 2008 Is there a way to keep the palettes from moving around every time I open VW? When I open VW the Constraints palette is in a different location and configuration from when I closed VW. Not a big deal but annoying nonetheless. Quote Link to comment
Dieter @ DWorks Posted April 21, 2008 Share Posted April 21, 2008 That's 'normal' I have this too and you can't fix it. Quote Link to comment
maarten. Posted April 21, 2008 Share Posted April 21, 2008 Do you also have it with the standard Workspace? 'cause I had it too some years ago and I found out that it was because my Workspace was corrupt. Quote Link to comment
Jodyb17 Posted April 21, 2008 Author Share Posted April 21, 2008 does that mean we should not attempt to create our own workspaces? Quote Link to comment
maarten. Posted April 21, 2008 Share Posted April 21, 2008 no, not at all, but sometimes, for several reasons, a file can become corrupt. So, if you try it with a standard workspace (or an other one that you haven't used before) and it does work with that one, then you can try to remake your workspace from scratch, and normally the problem would be fixed. Quote Link to comment
rDesign Posted April 21, 2008 Share Posted April 21, 2008 There is also a problem with OSX 10.5 Spaces screwing up palette locations / visibilities: VW2008 and Leopard - Spaces. Don't use Spaces if you're using VW2008. Tim Quote Link to comment
