Hugo Posted April 10, 2008 Share Posted April 10, 2008 Hello. In some drawings, generally ones I have imported from Autocad, there are lots of points called "3D locus" that appear in lots of places. I usually remove them manually, but it takes me sometime to do that. Is there any way to remove all them in one operation? Thank you. Quote Link to comment
Pat Stanford Posted April 10, 2008 Share Posted April 10, 2008 (edited) Check out Custom Selection under the Tools menu. This should let you select all the loci and then do a single delete. Pat Edited April 10, 2008 by Pat Stanford Quote Link to comment
Ray Libby Posted April 10, 2008 Share Posted April 10, 2008 You can also create a script through custom selection that you can use to select 3D locus. Quote Link to comment
Hugo Posted April 10, 2008 Author Share Posted April 10, 2008 Excellent tips!!! I did it in 30 seconds! Great! Thank you very much! Quote Link to comment
