Joz Posted March 11, 2008 Share Posted March 11, 2008 I seek a line with an x at each end, and x's spaced (reasonably) regularly along the length that are tied to the line and that all behaves like a line. Is there a script someone's written? An easier way than making an x and duplicating it along the length of the line, and then grouping all the bits together? A hidden x-line type? I sorta think I had one back in v.9 or 10, after poking at the dashed line editor for ages... but I've forgotten if/how that happened. Thanks much... -J Quote Link to comment
Tom G. Posted March 12, 2008 Share Posted March 12, 2008 There is a tool to do just what you want but it doesn't seem to have been originally optimized for a fence, judging by its scale. Make a polyline to represent the path. With it selected, go to Modify>Objects from Polyline. Select Repetitive Unit. Choose your symbol from the OIP. Choose Misc. Choose Site Fence. As you will see, the scale is all wrong. Play with the pitch to get the spacing you want. Ungroup and dbl click on an X to get to an editing pane where you can then set the text size. After having done all this, it may have been faster to build it from scratch. More on this subject here: Convert to Lines #25 (scroll to find) http://converttolines.blogspot.com/ Quote Link to comment
Joz Posted March 12, 2008 Author Share Posted March 12, 2008 Ok. I've had better luck making my own x symbol. The scale isn't the issue... I'm happy to mess with the scale of the symbol. Un-grouping the repetitive object thing takes me back to the group-of-a-million-objects that I'm trying to avoid. I'll cope without the x at each end of the line... since it's a symbol, I can just add 'em as needed. Thanks for your help. Quote Link to comment
Gerard Jonker Posted March 12, 2008 Share Posted March 12, 2008 Ozcad has such a tool in his Essentials. Ozcad home page Gerard Quote Link to comment
beanus Posted March 12, 2008 Share Posted March 12, 2008 cant find this this tool on Ozcad? Quote Link to comment
Joz Posted March 12, 2008 Author Share Posted March 12, 2008 (edited) me either... ? Gerard, can you post a more specific link or search term? Thanks. Edited March 12, 2008 by Joz Quote Link to comment
portamigra Posted October 1, 2008 Share Posted October 1, 2008 If anyone else is trying to make a line with x's, I'll let you know I successfully made the repetitive unit tool work fine. Do not ungroup the line after creation. In order to easily change the way it looks, just edit the symbol that you chose to repeat. Use the 'pitch' field on the OIP to adjust the spacing along the line. Presto, problem-o solve-o the address below is a print screen with two repetitive unit lines that i joined at a right angle. As you can see, the left line has more spacing (15') than the right line (5'), AND the X that is repeating has a box behind it (I edited myself) to created a 'break' in the line. The box has no outline, but it does have fill. With this method, the line is still a repetitive unit object and not a billion different pieces. http://i266.photobucket.com/albums/ii261/portamigra/RepetitiveUnitToolforFence.png Quote Link to comment
