K Irish Posted February 22, 2008 Share Posted February 22, 2008 (edited) Is there a way to change the order of the sheet layers in the drop down layer list once they have been created? Leading to my second question: In the batch print dialogue box, after adding sheets in a particular order and saving the batch print set, the next time I recall that saved set, there are only 10 of the 20 sheets that are recalled of that set. Is it possible to save a batch print set with more than ten sheets? Thanks for your help. Edited February 22, 2008 by K Irish Quote Link to comment
gmm18 Posted February 23, 2008 Share Posted February 23, 2008 Sheet layers are organized in alpha-numeric order based on the sheet title. One thing to note, since VWks is sorting digit by digit and not complete numbers, A10 will be placed above sheet A2, to avoid this you can simple add a space, yes just hit the space bar, before "A1-A9," then they will be in order. If you have 20 or more sheets, add two spaces before A1-A9, and one space before A10-A19. In terms of the saved batch print set I have never needed to use that feature. Quote Link to comment
K Irish Posted February 23, 2008 Author Share Posted February 23, 2008 Thanks for the tip gmm18. I will change my titles. Ken Quote Link to comment
