CS1 Posted February 22, 2008 Share Posted February 22, 2008 Is there a way to create an equation so that when using the IF command a cell to the right of the active cell is shown also. In other words if I have the following information in my cells A1: 10 A2: 20 A3: 30 A4: 40 A5: 50 B1: example one B2: example two B3: example three B4: example four B5: example five In cell E1 can I have an equation which does the following If C1 = '20' then show the value of the cell to the right of A2 (which is B2 "example one") in cell D1 So in cell C1 if I enter '10' the text 'example one' will show in D1. So in cell C1 if I enter '20' the text 'example two' will show in D1. So in cell C1 if I enter '30' the text 'example three' will show in D1. etc etc etc I know i can create this by using something like the following in D1 =IF((C1=A1),B1,IF((C1=A2),B2,IF((C1=A3),B3,IF((C1=A4),B4,IF((C1=A5),B5,')))) This does what i need the only downside is I can't just click on the cell B2 and change the text from "example two" to "test two" and have it change in the equation in D1, I have to manually change it in the equation line. I hope someone can understand what I have just tried to explain Quote Link to comment
Pat Stanford Posted February 22, 2008 Share Posted February 22, 2008 I understand what you are trying to do and I don't think you are going to be able to do it in a worksheet in VW2008. There is no equivalent to the Excel Lookup function in a WS. Pat Quote Link to comment
